1 - 8 of 8 Posts
When i bought my house i knew this was going to be a problem down the line but i have a slop sink in my basement that has my washer draining into it. The drain pipe for the slop sink goes out the foundation wall and i have a stone patio above that i can not dig to find what it drains into. I know it does not drain into the main drain of the house b/c the main drian is in my rafters...
My question is how can i figure out what my slop sink drains into??? maybe a drywell???
Also my slop sink is now really clogged and there is black stuff that smells really bad comming out of it... I have draino poured into it for now and i have wait 1/2 hour to see the results.
Anyone have any ideas for me?
Premium Member
prolly a drywell. Check with your sewer dept or bldg. dept for sewer records on your house. They may have the original as-builds for your home. Usually the pit is close to the house- say 10ft or so
Thanks for all the input... drain did nothing so i am thinking I have a bigger problem... I think the drywells is gone/collapsed. Since its under a brand new patio I can not replace the drywells. I want to get some sort of pump installed. The only things that will ever drain to this is a high efficiency washer, slop sink (hardly used) , sink in my finished basement. Not yet installed so I am not sure how much usage it will get.
I don't mind opening up the concrete floor and installing a basin and pump. I should be able to tap into an existing vent.
I am just not sure what products I should be looking at. Any ideas?
I know I am in over my head and will calling my buddy who is an awesome plumber. I just hate bothering him. He shows me what to do and then comes back to inspect my work and makes changes he sees fit.
Any ideas as to which products I should look at?
Premium Member
use the search feature at the top and center of this page. Theres been people here asking the same questions.. You should find some good info.
Premium Member
Just a thought -- I put in a 30gal with a 1/2hp grinder yesterday. It came as a complete package. Cost 500.00 with misc. pipe and parts included. It took 2 of us all day to install, including busting out the floor, digging, piping and electrical. I know its bigger than you need but you might consider something like this. If you ever consider adding a bathroom in the basement you'll have the pump for it.
Depending on the height of the sink, installing a basin (holding tank) and waste water pump might be possible on the floor so you don't have to dig a hole in the floor. That is, if you do not foresee installing a bathroom down there.
1 - 8 of 8 Posts
