I'm putting a 240V baseboard heater in my son's bedroom. Conveniently, the heater will be 4' under the electrical panel, so running a 240V cable should be relatively simple.
That being said, it would be very convenient if we could also run a 120V outlet on the same circuit.
Is the following legal/safe/to code? (I'm in Alberta/Canada)
- Install a 240V 15A breaker. (the heater is 1000W, so this should be enough)
- Run 4-wire 14AWG or 12AWG wire to the heater.
- The 4-wire would be +120V, -120V (180 deg out of phase), neutral and a ground
- Use the +120V and -120V and ground for 240V
- Use 3 wires (+120, neutral, ground) for the outlet.
Is this legal/safe? Can I use standard 14AWG cable even though it's a 240V circuit? What am I missing here?
Everywhere I've read indicates a subpanel is needed, but its typically when adding a 120V outlet to a 30A circuit. If the breaker is only 15A, can I just use "half" the circuit for a standard 120V outlet?
