Hey all,
Hoping you can help me diagnose a problem I have in my remodel: I’ve got one circuit for bathroom lights consisting of 4 LED cans (Lithonia 4JBK) on a Lurton dimmer, GFI protected since one of the cans is over the shower. My issue is that I have an extremely slight flicker in the lights that I can’t diagnose. When I say flicker, it’s not a strobe at all, just a slight variation in the brightness, like it’s quickly and erratically going back and forth between 100% and 90% brightness. It’s not the dimmer or the GFI since I’ve tested them by bypassing each alone and both at the same time and the problem persists. The really weird thing is if I hook up only 2 of the cans, the flicker goes away. The 2 cans don’t have to be in sequence and can be any random 2 of the 4. As soon as I add a 3rd can back into the run, the flicker comes back. It’s almost like there’s an inconsistent flow of power through the line that shows up once that 3rd+ can is hooked up.
I’ve used the same cans and dimmers for 6 other zones and 30 other cans with no issues, which again leads me back to something with the circuit.
What else can I do to test and diagnose the issue? I’m stumped over here! Thanks for the help,
-Mike
-Mike
