1 - 8 of 8 Posts
The last 6 steps or so on my staircase slant to the right about .4 inches to .75 inches at its worst. The slant goes towards the wall as seen in the pictures. What could have caused this and is this something to fix or just live with. The house is about 20 years old.
Thanks
Gerard
Could be lots of things. Could have been that way when it was built, center of the bulding is sagging, ect.
Thanks for the reply...off the stairs nothing else is sagging...there aren't any slants related to this one....
What should I do to eliminate the reasonings? Is this something that can just happen?
Super Moderator
Are you sure the stairs are sagging or is the carpet worn?
It was either build wrong, something sank or least likely something rose.
Disabled wood vet
Its slightly possible you could have a cracked stringer, which would require major remodeling.
Is there a room you can get to under the stairs?
Sent from a Samsung Galaxy S2
Discussion Starter · #6 ·
Can't easily access stairs...it doesn't bother me enough to go to town on it...just curious as to why...I'm guessing cheaply built with a little settlement.
Super Moderator
If it has just sagged in the recent past I would be concerned, something isn't right and I would be concerned enough to find out why.
Can you access the bottom of the stairs? What does the stringer sit on at the first step? Does the floor, at the bottom of the stairs, feel bouncy or sagging?
1 - 8 of 8 Posts
