Hi all,
The room that was once an open air brick garage/carport in my mid century ranch was converted to a living room years ago.
When they did this, they added windows everywhere and a big double slider patio door where the big opening was as well as a fireplace. They also put in a boiler in the basement and radiant baseboard heaters in the room under two sides of the windows. (see attached drawing)
I bought the house about 10 years ago and this is where we spend all of our time. I quickly realized that AC would be needed so I installed a cassette AC only split system in the ceiling. It was the best solution as I had room in the attic above and it has worked pretty much great with the exception of needing to be charged twice now.
Long story short, I really want to get rid of the boiler in the basement and the footprint it takes up. I did a thread a year or two ago chasing down a solution that would have reduced footprint by making EVERYTHING in the whole house's system hydronic but I think now that getting a heating and cooling unit to replace my AC would be a winning proposition. I know they are rated differently and that I might need to get a unit that operates at low temps for the climate here (Cincinnati, OH)
Any reason to think this wouldn't work?
is 18,000 BTU overkill? There is a lot of window space in here. I can't remember the specs on the cooling unit I have now but will check when I'm home.
Any recommended units?
thanks!
thanks!
