All,
This is question # 2 based off of my question "2 x 6 sister" posted yesterday afternoon. The feedback was very good so I thought I would go a little deeper to see what other type of advice I could get.
The scenario is this:
Two additions were put on the house. One was in the 50's, the other in the 1980's or so. The 80's addition was put on top of the 50's addition. These were put off the back of the original four square house. When they did the 80's addition, they just more or less rested tapered 2 x 6's (to practically a point as seen in pictures) on top of the old roof. No ledger or anything was added.
We have decided to sister the 2 x 6's with 2 x 12's in this 50's addition. We have supported the 2 x 12's on a short wall. Previously they just had a few supports just fitted tightly between the old roof shingles and the new rafters. See the pics of our short wall.
So, after all that my question in this area is this: Two of the Old 2 x 6 rafters were not flush with the rest of the 2 x 6's. When we sistered the 2 x 12's and fit snug against the roof and followed the same pitch of the plywood naturally our new sisters were not flush either at the point of the temporary wall. Hopefully this is evident by the pictures. I have added an extra block in there so that you can see which item I am referring to. Should I re-sister this problem area so that it is below the plywood roof and flush with the rest of the 2 x 12's, or should I shim the top plate/rafter connection so that it is flush? I had to just do it this way temporarily until I could support the roof, which was pulling away from the house as built. Amazing it did not happen sooner.
Thanks all for your time! I will have a few more questions as we go along. Just want this area to be as strong as it can be without ripping it down.
Thanks and let me know if you have any questions!
Tom
Tom
