1 - 16 of 16 Posts
Hello,
I recently installed a single bowl sink in the kitchen. Problem is, I no longer have room for a disposal with the current drain setup. Can someone tell me if there is somewhere that I can cut the pvc prior to the "Y" fixture to reduce it to one drain?
Thanks!
· Retired Moderator
You are in trouble----those are all fittings and the only pipe is the one coming out of the wall---and it is to short to simply cut off and glue in a new fitting.
How handy are you?--That pipe can be removed from the wall using a 'Ram Bit'--
Interesting! I didn't even know this was an option! I think I could manage that, but where would I make the cut? Then I would drill it out to fit a male connection? Thanks for the help neighbor!
Thanks Mike!
I think if i carefully cut with a hacksaw as close as i can to the "Y" connector, I can keep about a half an inch of the male side. Is that enough exposed to get a female piece to cement on? Worst case, I can try that and drill it out if it doesn't work right?
Thanks for the help!
· Retired Moderator
You might get lucky----you could try cutting through the Y-fitting and pry off the bits of flange--then file/sand the glued area --3/4" is needed to a good bond---
Discussion Starter · #9 ·
So I made the cut and I think I have enough of the pipe left to cement a piece on. Here is a picture. Let me know if you think otherwise. So, I would now just cement on a 2" male threaded piece and connect my p-trap to the disposal right? Also, does a single bowl need any additional venting? I was thinking about it and wondered if two bowls acts as a vent and if I would need to vent this drain since it is in a kitchen island. Thanks again!
· Retired Moderator
Give it a try---I usually hang the disposer and add the P-trap before installing a fitting to the drain---then see if the P-trap will go straight in of need an angled fitting before the trap adapter.
it leaves you the option of adding an angled fitting if needed---
Discussion Starter · #14 ·
Hello all,
I believe I got this done last night with your help! It seemed like there was plenty of PVC exposed to cement a fitting to and the p-trap connection was a piece of cake!
RJ - yes, the sink is in a kitchen island and the house is on a basement. I did not add any additional venting inside the cabinet and it seems to drain just fine.
Thanks again for all of your help!
· A "Handy Husband"
You may have this venting set up. It is called a Siamese vent
Or someone may have buried an Air Admittance Valve AAV in the wall'
If you have a Siamese vent it should be obvious by the plumbing in the basement.
Reactions: andybeck
1 - 16 of 16 Posts
