I'm converting my old single vanity to a double vanity. The space is 60" wide and the old vanity was located against the left side wall. I plan to tap off of the existing water and drain lines to run over to the right side. My question is how do I do this so it is code? Harris county is pretty lax about codes so whatever the general rule is concerning this arrangement is good enough. What kind of fittings should I use?
I've attached a picture of what I plan to do, the obviously not to scale but you get the point.
