I have 4 of the Pacific ballast and 2 of the Advance ballast as shown in the attached images. How many amps am I pulling on the entire circuit?
If my calculations are correct, each is rated at 40w max, therefore 240w total, so 2A if calculated theoretically and 3.64 if I utilize the amperage ratings on the ballast.
The reason I am asking is because I have a Lutron remote setup that only has a switch rated for 5A, not a typical 15A and I want to ensure I do not go over the rated amperage. Also, is it fine to put a 5A switch on a 15A or 20A circuit? (not sure if its 15 or 20 at the moment).
