I get a call from a moduler home company to install the foundation plates on a new foundation.
I pick up the plans so I will know what to go pick up at the lumber yard and head for the job site.
I start laying out where the lumbers suppost to go and find out one wall is 2' to long.
I hear something coming down the road and it's the 6 "boxes" that get assembled to make up the home.
Little late now to make any changes.
No one was happy that day.
After a big delay to fix the foundation and the home is set in place the home owner ask me what it would cost to add a single car garage to the end of the house.
I give him a price and do not hear back from him until I get a call from the home owner saying the building inspector will not pass the garage he had someone else build instead of me.
Door knob was on backwards, they had taken a truss and just nailed it to the side of the house right through the siding to tie it to the house.
There was no 5/8 sheetrock used on the abutting wall.
The sheathing was installed 1/2" above the foundation so the foundation plate showed all the way around.
The only switch to turn on the garage light was a single pole switch inside the house.
There was to differant shades and two differant manufactures of the shutters.
The siding had been nailed so tight it was buckling as soon as the sun hit it.
They had wrapped the pressure treated over head door jambs with aluminum coil stock.
They used three pieces of brick moulding shaped coil to wrap an 8' length.
There was 0 flashing between the garage and the house.
Put the switch for the outside lights on the back side of the door.
