The exterior of my home currently comprises a thin layer of stucco applied over some white polystyrene insulation (1" maybe) which is presumably nailed to the exterior sheeting.
There are two things I would like to do, improve the insulation and change the exterior to either siding or shingles (preferably cedar shingles). The stucco is in good shape apart from a couple of nicks here and there and one area under the patio doors (see attached picture, which also shows thickness of insulation) but the doors will be replaced in the spring and that area will either be replaced by steps or a small deck.
I was planning on taking off the internal drywall/wallboard mix, replacing the insulation in the walls, assuming there actually is some, (its an old house and you can never be sure round here) and then adding new drywall. That should take care of the insulation part. But for the outside I was wondering if I could shingle right over the stucco or whether I would have to remove it and the polystyrene insulation first, in which case I might need to rethink my indoor insulation plans.
