1 - 18 of 18 Posts
So first off, what this little added decorative roof/outcropping officially called?
Secondly, what's the best way to access it? It's just out of my reach while I'm on the garage roof. I was think about using something like a pivit ladder tool and a 6' ladder, but maybe some sort of scaffolding would work better, or a combination of the two.
Thanks for any suggestions or pointing me in the right google direction.
It's not really decorative, IMO. Looks like someone simply put on an addition with a different pitch. Are you saying it's too steep to stand on?
If so, you should probably get a Guardian Ridge It anchor... put it under the ridge cap at the peak (as close as you can put it to the chimney) and then get yourself a fall protection harness and rope... and learn how to use them.
But you normally should not access a roof from a step ladder at all. It's a great way to tip the ladder over. You should be using an extension ladder. And so that it does not rest on the gutter and dent it, you can put a stabilizer/standoff on the extension ladder.
You're right, it looks like an addition, but it's not, all original to the build.
It's not too steep, it's just not wide enough, maybe 18" tops, so it's not like I can crawl up there. I can reach the left corner from the garage roof, but about 1/2 to the right side it's just too far. I think something like Nealtw drew up is the way to go.
The other side of the house has something similar, but it's closer to 3' wide, that has enough room to get on top of.
· retired framer
We built a few like that where they have a max sq foot on the lot so they just make one side smaller and do this to the other side for a matched look.
That is supposed to make the house look like it has a steep roof with a shed dormer. I once ripped one off a house and had a smooth wall.
Reactions: 52Caddy
Yeah I was looking at the part that is being worked on!
If they still allow wall jacks you could use them on the lower wall if it wasnt styrofoam. But a homeowner can do whatever he wants. Put plywood on the wall and use wall Jacks with ledgerlocks. Or build a temporary scaffold like we would do in the good ol days.
Now that I know what roofline you're talking about, it's still not decorative... it's the way shed dormers are built.
· retired framer
The 18" wide roof that is in the way is just nailed to the side of the wall, decoration. :wink2:
Now that I reread it, I realize that "wall jacks" might give you the impression of another product that raises walls... that is just what we have always called them. Similar to ladder jacks... but on the wall. I guess the technical name is sidewall staging bracket, or hanging wall bracket. But you cant use the hanging bracket there with no top plate to hang it from.
Here is the "wall jack" I'm talking about. In the old days you used to just nail them to the studs. I suppose these are "safer".
https://images.homedepot-static.com/catalog/pdfImages/59/5915f7d7-b835-42d1-91ab-c88f265865b3.pdf
Maybe it was a single story house then a second floor was added by raising the roof. Original roof line was preserved but the gable facia looks odd the way it sticks out in the front. I'd take little more time and get rid of it and not think about how the other side matches.
I would rent a staging and put planks over that little roof over the door, then another longer plank and plywood over both to make them into wide work surface. Rent staging planks or use long enough 2x12s. You can fasten through the shingles and repair later. 2x4 across the shingles also to make walking on the roof easier. Every little bit helps.
1 - 18 of 18 Posts
