if you're replacing sections of s/w, you don't want the new to bond to the old except in rebuilding-a-joint instance,,, IF its likely you're referring to apron/vest store bagg'd conc mix, it's fine - compressive strength should be listed on the bag,,, what will lower the strength is adding too much water
