Showerhead replacement
1055 Views 3 Replies 2 Participants Last post by  user1007
2
Trying to change out showerheads....Amidoinitright?
You see what I have to deal with, so tell me if I need something more or if I have what I need/what I need to do.
THANKS!
Should work. Just do not over tighten things.
So torque out the old one, screw in the new one? It's as easy as that?
If you need excessive force to get this shower assembly out you could have a problem. I doubt you will though.
Do wipe out the threads of the fittings for sure if you can reach them.
As you fit the neck into the wall, go slow to make sure you engage the threads properly. You don't want to cross thread that hidden connection or you will have to pull the wall apart to fix it.
