I am rebuilding a shower and ripped everything down to the studs. The back wall studs are installed with the wide side out to which the drywall was attached. The floor plate looks like it is a 2x4 cut in half length wise. I guess this was done because of the main waste pipe and a vent pipe. The header above these studs also appear to be a 1x2 or 2x2. I want to remove these studs and replace with 2x4s the "normal" way, but I belive this is a load bearing wall. There is another bathroom above this one. Anyway, do you guys have any tips or advice on how to replace these studs and floor plates without compromising the structure of the room above it? Sorry about the rotated 1st and 4th picture.
Thanks.
Thanks.
