Yep......just peel the paper off one side.someone at home depot suggested sheetrock as a good flame protection while sweating the lines back into the wall; said the paper will burn away but the gypsum works great as flame protection. Is this a true statement?
Very common, just put a plug in the bottom post.finally found a site that identified the bottom line as the tub spout which there is none. Assuming purchased in a contractor pack and "roughed" the copper into the valve prior to installation in the wall and used a shower/tub valve for a shower only installation
thank you Griz
