Hi everyone, I am new here. I have searched the forum, but couldn't find what I was looking for.
I have ripped my shower stall down to the studs, and built it back up again. I am at the point of installing tiles, but have a few questions before I begin.
1) Is it ok to install the bottom row of tiles butted right up against the floor, or should a gap be left, and if so, what should that gap be filled in with if anything. Or, would it be best to cut the floor tiles and bottom row of tiles with 45 degree edges and grout between them? The later seems like it might not be the best to prevent leaks.
2) Similar to the first question, what would be best for mating up the corners? Should I just butt the first wall of tiles up against the backerboard, then leave a proper sized gap between the tile face of the installed wall and the joining wall and grout between, or would cutting the mating edges at 45 degress be better?
3) I understand that it is easier to use smalled tiles on the floor, but is that a requirement? I am using 13x13 on the walls, and wonder if it is possible to use them on the floor as well.
4) Speaking of floor tiles, it would appear that the tiles I picked are slightly thicker that what was previously there. Is there something that would extend the height of the floor drain, or will I just have to try and smooth the slight height difference during the grouting phase?
Well, I think that is it. Any help with any of the above questions would be greatly appreciated. Thanks.
