So with the help of many of you, I have now tiled 6 floors and a backsplash with great results. Now I want to tackle a shower.
My shower will have tiled walls and has a Kohler shower pan insert (basically it is a floor pan only) already installed. I have cement backerboard on the walls.
So, starting the pan installed and cement board on the walls, what is the next step? I use Ditra for all of my projects and have heard many people recommend Kerdi, which I assume I will be using. The tile will be porcelain.
Any advice about what to do with seams, thinsets to use, Kerdi or waterproofing that is necessary, etc. is appreciated! I'm a true rookie with showers so don't know where to start!
