1 - 2 of 2 Posts
I am converting a tub to shower and have a few questions....
PLAN
slip sheet , wire mesh w/ mud for pre-slope & Red guard for pan. Backer board on walls w/ niches (not prefab) and a Better bench. 4x4x16 cmu w/ 2" cap for curb.
QUESTIONS
* re: mesh for pre-slope- Can i use "hardware cloth" 19 gauge 1/2" mesh w/ galvanized zinc coating?
*after pre-slope is constructed should i put the Redguard on (as pan) then the cmu cap and proceed with the mud for shower floor?
*should I use lathe on curb?
*does the mud on curb need to be 3/4" thick on all sides? ( i am trying to calculate the space between the existing saltillo & CMU for the curb to allow for all phases and a grout joint)
*should I Redguard the studs around & behind the niches before i put the backer board in it? Then red guard the niche again?
*one last question, how much Redguard should i need? i bought a 1 gallon bucket and a 3.5 gallon bucket.
I would appreciate any input.
Thank you,
Christine
If you can get metal lath, that is what I would use.
Redgard is not needed on the preslope.
1/2" is fine for the curb on the sides. 1" for the top.
Redgarding the studs? NO. That would be anticpating a leak. The niche needs to have cbu all around, taped and Redgarded.
1 gallon should do the job.
Here's some info: http://www.ontariotile.com/preslope.html
1 - 2 of 2 Posts
