1 - 11 of 11 Posts
Hi i am re-doing my first shower stall.
It is a three sided shower stall built in the 90's.
Due to water leakage behind the tiles i have decided to remove the tile and start over with a fresher look.
The wall tiles have been removed to the studs.
The shower pan remains.
I am looking for advice on the shower pan removal.
It looks as if it is tile + 1/2" cement+ membrane below that.
The drain is centered.
Can I:
  1. try and remove the tile and avoid removing the cememt?
  2. Remove everything so i can redo the waterproofing features.
Any advice on how to avoid the drain pipe?
Any advice on the best tool?
  • Cold chisel?
Paul
Retired Moderator
I'd redo the pan----Just break it up with a hammer---the drain set will need replacing so expect to open the floor and cut out the P-trap---Post a picture for more exact directions.
Is this a wood framed floor or a concrete slab?
Building a shower pan with pre-sloped mortar bed, liner and curb.
Some good reading to give you an idea of what you are breaking up-----Mike----
Thanks for the quick reply.
In addition thanks for the reading material.
Was not expecting to do any work to the drain, so i will begin my research.
I have attached a photo of my shower pan for your reference and for any guidance.
Paul
Retired Moderator
The pan looks good from here---You may be able to reuse the drain set---I wouldn't ,I like every thing new when a shower is re done.
Your plumbing supply house will have the drain set with a square cover--MUCH easier to tile to---
Be sure to do a 'flood test' on the new liner before packing the base---24 hours---it's the best insurance that a first time pan maker can buy.----Mike----
Thanks Mike,
I will pick away at the tile and concrete tonite.
Is there any risk of me cracking the drain pipe?
Will the concrete fracture and come away from the drain pipe?
I also note that i missed your original question.
The shower is wood framed and sits above a crawlspace.
Paul
Discussion Starter · #6 ·
last few questions.
When rebuilding the shower pan i have read about the schlutter system.
Will this work in my application?
In addition any thoughts on if i left the shower pan as is and retiled the walls.
I am guessing that they are commonly done together to ensure waterproofing etc.
Paul
Retired Moderator
If you are absolutely sure that the pan is still sound--you could remove the tiles--and reuse the pan.
The drain assembly is a two part thing---a base drain that is glued into the pipe and clamps the membrane ---and an adjustable screw in top that holds the chrome cover.
Most pans are not built correctly--water gets through the concrete and reaches the liner.
That water is supposed to drain away into the lower drain--
Often the liner is not pre sloped to the drain---thus leaving the concrete to soak for the life of the pan.
Result--rotten -soft concrete----
I'd want to replace the pan---20 years of use---I'd say it's paid for itself.
Building a new pan will typically cost $135.00 in parts---$35- for the square drain set---$70 or so for the liner and $15 for 3 bags of masons mortar.
Add a new P-trap and a few hamburgers---$135
I do a lot of these pans---This is the rough order of things---
Demo----add new drain set and P trap--pack a pre slope---add liner(folded corners--no cuts ever!)
Durrock the walls--No nails or screws below the curb height.
Pack the base
mesh the curb
fat mud the curb.
Retired Moderator
Bud Cline or Jazz man will have to fill you in on the Schluter shower systems---they have a fine reputation and are faster than the old fashioned mud bases---
But I have never used them myself and think advice on those should come from someone with real hands on experience.---Mike----
Discussion Starter · #9 ·
I will follw the steps noted.
Any tips on the demo?
I am currently using a 3" concrete/brick chisel and hammer.
I am trying to decide on the best course of tact.
Would i fracture to small pieces and see if it separates from the membrane?
In my short 15 minutes with hammer and chisel i am not making fast headway.
Lastly will everything come up cleanly from the plywood base?
Paul
Discussion Starter · #11 ·
Great advice.
I got some better chisels and made quick work of the pan.
I will work on the drain set, pre slope and liner for the wknd.
It is a long weekend for the recognition of Queen Victoria's birthday.
(think she is the queen mum's aunt, but i should look that up.)
Paul
1 - 11 of 11 Posts
