rbannan1,
I don't know of a method that tells you to install felt paper and lath on a slab floor. Definitely not the paper. 80 lb. Portland to 160 lb. of sand is too rich and will be more difficult to work with. A good shower floor mix is 1:4, but it's always measured by volume, not weight, since we don't keep "no skinkin scales" :wink2: on the truck, but we do have shovels. Volume vs weight may be close however.
There's nothing wrong with this method, (liquid membrane vs. sheet shower pan between pre-slope and deck mud), just be sure to follow directions if a mesh is required at the inside corners. Your method might even be better if the pre-slope is omitted in the other method as is often the case. We often see showers built with a pvc shower pan, then the genius nails/screws backerboard to the inside and top of the curb.....there goes the waterproofing.
I believe the surface membrane method is superior to some of the old methods. I like the Kerdi methods, but I won't get off track now.
As most tile pros know, liquid membranes have been around for many years (I would say at least 35 years), and the reason they were developed is the failure of the old method in some cases. Mold and mildew in showers is the main reason for their existence, and the world is better off. There are many brands, Redgard and Hydroban being the two most popular.
Jaz
