Shower Drain Install Problem w/ Shower Liner
Ok, I know that every shower should have a shower pan liner installed. However, this is my problem:
I have a shower in a basement that was roughed out and never completed about 15-20 years ago by my Father. It was built on a concrete slab as it is on the basement level. The shower has a sloped mortar/concrete base and this is where the shower was stopped.
The problem with installing a liner is that it would be a very difficult job to install the necassary shower drain/flange needed for a shower liner. The drain installed is an iron pipe that comes up flush to the mortar bed with a shower drain attached to the top. So to install the drain flange, I would have to cut off a few inches of the iron pipe and cut out some of the concrete around the pipe to make room for the flange.
Therefore, is it worth all the effort to install the flange/liner? Would I just have to use a concrete saw? Is there a drill bit made that I could cut the iron pipe out from the inside of the pipe?
