The shower head in my shower is leaking. When I turn the faucet I can feel that the washer inside is not quite seating properly and so I think it needs to be replaced. Even after carefully closing the valve, spurts of water come out for about 2-4 times every 10-30 seconds, then the leaking stops. I know it stops as the shower head is dry by evening. It appears I need to remove the front plate (see photo) in order to get at the washer. This would require shutting off the water supply.
Any tips on handling this? I can shut off the water by closing the valve leading to my water softener - not sure if I can or should turn off the hot water tank. I think I could use a razor blade around the caulking to remove the plate. I have enough tools and bath caulk. I'm hoping that the washer inside is easy to replace so that I can head straight to Lowe's or Home Depot and get a replacement. I suppose it would be best to get the new washer before-hand. I'm not sure what to get until I see what it looks like.
Any help appreciated. I'm hoping I can do this project myself.
Thanks,
Chris
Thanks,
Chris
