Hello all,
I ripped out the shower in our basement that was put in sometime in the 60's. It was ugly, but it was leaking so we have decided to remodel. I'm not sure if I'm going to put in one of those plastic shower stalls or tile it.
My concern is the drain. The base consists of an 1 1/2" to 2" thick concrete pad(poured directly onto concrete basement floor)with tile on top of that. The drain appears to be solid cast iron surrounded by the poured concrete of the basement floor and the base pad. Meaning, I can't move it without ripping up the concrete and I can't adjust the height as far as I know.
If I go with a pre-fab shower stall the drain is off center by about an inch. Being an old style drain I don't even know if I could connect a pre-fab shower stall to the drain. If I decide to tile it I would need to add the rubber barrier and another layer of mortar. Which means I would have to raise the height of the drain. Another option would be to bust out the existing pad and then put the rubber down and mortar that leaving enough drain above so I could tile up to it.
Just looking for options/ideas. Maybe there are parts out there I don't know about to help adapt the old with the new?
I would rather go the pre-fab shower stall route if possible as it will be much faster. Although tiling it would be a fun project too!
Thanks for any help,
Ron
Ron
