Hi trying to help a girl I know with an old plastic shower door problem. Her door is sagging and won't close. Upon viewing it looks like the bottom pivot is broken (looks like a metal pivot with plastic/nylon insert. The shower is an 80's cheapo shower (plastic walls, base, glass doors/glass surround).
Until they have enough to fix it correctly by replacing it, I'd love to fix this issue for her. From what I can understand, I'd have to have a scrape or cut the old silicone under the metal, remove the door, and lift the base that is covering the pivot block (not sure how that is secured). Replace and silicone. But I am unsure if this is correct or not. If anyone has done this could they chime in? Thanks David Trying to get a picture of the entire door.
Look at the top hinge to see if there's two screws that can be backed out, and the pivit point moved to the left so the whole door can be lifted out to get to the bottom one.
Ever worked on a Bi Fold door before? Should work the same.
