Mod Bit Coating
OK heres the short version.
Both APP and SBS come in a torch grade.
SBS has a much lower application temperature so it can be mopped in special steep ASTM D312 Type IV asphalt, or torched.
APP Must be torch applied because it has a much higher application temperature than can be acheived by heating asphalt and mopping. Basically the asphalt would reach its flash point before it got hot enough to properly fuze APP.
APP is more resistant to UV light, and does not need to be coated, but it is good to do so, as it extends its life. Wait to coat it though, as described in my previous post, for the reasons stated.
SBS must be protected from UV because it is much more susceptible to damage from UV light. You did not say whether your roof was granular surfaced or smooth. The top ply of all SBS roof systems is usually granulated. APP can be either.
If I were you, and my roof was APP, I would coat it with two coats of aluminum roof coating. Re-apply as needed. Usually about every 7 years, depending on the product.
If my roof was a granular surfaced SBS, and it was a two ply roof, I would not coat it. If it was installed as a single ply I would coat it with an elastomeric white coating as recommended by the roof system manufacturer.
The fact that you have good drainage is of paramount importance with the use of mod bit. It does not tolerate ponding well.
