I'm creating a first floor wet room and pulled up the floorboards and found joists in mixed condition. Short question is should I replace them? If so, am I right in thinking 6x2 at 400 centres should suffice in this room which is 2m x 1.7m. According to the tables I should be well within the deadload limit.
Additional benefits of doing it would be the opportunity to level the floor as the 200year old beam the joists dovetail into is quite bent (although solid otherwise). I'm assuming I should use joist hangers at the beam end with the recommended nails (would rather use screws if that is acceptable?). I'm not sure what to do at the other end. The current joists pass over and rest on a brick wall and carry on to another wall. If I saw off these joists this side of the supporting wall would that affect the structural integrity of the rest of those joists?
