I have de-commissioned several appliances (base-board electric heaters, window air conditioning unit).
I also need to add 2 more wires which may needs up to slot (1 wire needs 2 slots and the other needs 1).
So I looked at the panel and how the horror. Wires are all over places and it's hard to insert in another one. Not only that, there are only a few labels here and there and some are un-intelligible.
I will need to find out which cables I have decommissioned. I also need to find out which wire is responsible for which outlets/light switches.
Then somehow insert new wires in. This when I want to redo the hookup.
My plan is this:
1) Find out all the breakers and where the outlets/switches are affected.
This can be trial and errors. It's a relatively large house. Any idea how best to do this?
2) Label existing wires with some tag and put the ampage on it (based on the breakers). If not, I have to find the gauge (by reading or measure the diameter) later.
The information is for granted and will be verified later. But at least I have a base line.
3) Remove all the wires from the breakers.
4) Start putting them back in an orderly fashion.
Would someone please advice me on what best path to go? Should I just go the dirty way and try to insert one into an open slot once I find it? Or should I re-layout wires in the panel to make it ok in the future.
the tool didn't work well
it just works on the basement, same area as the fusebox. So, it appears that it has distance limitation. Also, not all path in the basement works.
Not recommended at al.
I ended up having someone to help out by keep turning on and off the breakers.
One thing I noticed was that there are about 4 circuit breakers (maybe 6-7 pair of wires) responsible for all lights and plugs in the house. That's pretty crazy. I thought they would balance them out, after reserve some for 240V.
