Sorry for the long winded post, any insight is appreciated:
I discovered a pit 3' in diameter and 7' deep (dry well?) in my back yard. This was discovered because I had roofers replace my roof and they set the dumpster on my back patio/concrete slab. The concrete slab cracked and that is what initiated further investigation. You can see from the pictures that part of the pit is exposed on the grass (this was covered with 2'square paving bricks, so it wasn't obvious that there was a pit beneath it!).
Now that I have a cracked slab, I would like to cut the cracked slab out, fill the pit with gravel, and pour a new slab (extending it out about 2' into the yard so that the entire slab covers the pit as well as to allow more room for my outdoor kitchen). Since this slab will become the foundation for my outdoor kitchen, I am hesitant about leaving the hole unfilled. On the other hand, I'm concerned that filling the pit will cause drainage issues...should this be a concern? There are no inflow pipes into the pit, but obviously water finds its way during heavy rain storms.
My yard slopes towards the house, and the concrete slab/patio slopes away from the house (i.e. right now this pit is a low spot between the house and the yard)
My concrete slab/patio is about 12' wide - which makes the edge of the drywell closest to the house about 10' away from the house/foundation
