Hi to all, I recently had a 2 ton fujitsu installed to heat/cool about 750 sq.ft. Because of somewhat limited locations for install the unit has a wall in front of it at about 14'.The vents are pointed at the ground and I think the are is going acroos the floor,up the wall and back to the cieling where the air intake for the unit is located.Could a hard wire thermostat located somewhere else stop the cycling?I tried turning on a cieling fan thats near buy but even on low the unit never shut.My average consumption is around 40kw a day and 50kw on laundry days.Thanks in advance for any help
