1 - 13 of 13 Posts
Just bought this house. Siding guy put the vinyl siding right over the shingles as you can see. The brown shingles. Not should if the are the asbestos or fiber cement. They were put on in the 60/70's. We're installing new vinyl siding. He used vinyl siding that had the foam insulation( you can see the white foam in the pic) as part of the siding. I've never seen that. Is that good?
1. Is it ok that he went right over the old shingles?
· retired framer
That was my next question. No need for foam under the new vinyl we install?
Removing the shingles has to be dealt with properly even where you are just making windows bigger.
With out removing all the shingle getting full value out of extra foam insulation on the outside might be tricky or a pain in the ass.
1% or more by weight is legally considered asbestos containing. A friend had some asbestos siding tested and it was 60% asbestos. Any disturbance, even pulling out a nail, is an asbestos project. In NY a contractor has to do an abatement project but a homeowner can do whatever he wants to do. As the owner you can rip it off with no precautions if you feel like it. Not that I advise that, but it is legal. That is according to NYS Dept. of Labor Code Rule 56.
It's a guess but ALL name brand vinyls should be about the same thickness and quality. The difference is in the design, look. There are more expensive vinyls that resemble cedar shake and other materials that look more expensive. Homedepot vinyl, I think, is thinner for lower cost and such but as far as longevity and impact resistance, probably are same. Depends on the kinds of impact but nobody assumes huge hail storm and such. Then all bets are off. Cheaper, thinner siding could make the difference in how it looks later. How the joints lay flat on eachother, eg. Ask your installer for the brand and ask again here or search yourself. "(name) review" and such search should bring up pages of opinions.
You can keep the old siding and it is another barrier against the weather, but it is another material that will hold temperature. Ideal would be to remove it and add insulation. But with inside renovation like yours, no return on your effort and money. All flashing must be done as if the old siding was your sheathing. Also who knows if old siding was properly flashed? Now is the time to do the work properly instead of finding out later.
1 - 13 of 13 Posts
