1 - 6 of 6 Posts
Hello, I am planning on sheetrocking the basement in my house. I have a walk out basement so one wall is facing the outside. And there are two walls that I will be sheetrocking that are below grade level. I am wondering what types of insulation are best and how to insulate.
When i took down the old paneling there was the fiberglass R something behind it. Is the fiberglass rolls good enough or do I need to put the vapor barrier up too.
Thanks in advance.
· Registered User
Where are you located?
Gary
· Registered User
Ok, just to clarify this. Since I live in North Dakota I don't need a vapor barrier? I can just use the fiberglass rolls of insulation against the concrete basement wall? I'll check what rating I need. But so it'll be concrete foundation wall, then insulation, then sheetrock?
thank you
· Registered User
1 - 6 of 6 Posts
