Hi. We just moved into a home that has sheet vinyl directly on top of a concrete slab on a porch. Moisture is coming up thru the slab and to the vinyl. I really do not want to have to waste this new flooring. Can i put down 6mil plastic visqueen under the sheet vinyl? if i do, how will the vinyl adhere to the surface? will it just lay down or is there adhesive that can work? Are there any other options. I thought about using drylok first but it will cost a lot of money because of how many gallons they say i would need.
Thanks for your help.
Beck
Beck
