First off, thanks to all who have contributed to this site. It is amazing how much I've learned here without even asking a question.
I just found out the old dilapidated shed I thought was my neighbor's is actually mine. (long story) Now I want to make it usable instead of hiding it behind the bushes. It is 12' x 16' with 4 in block walls on a slab.
It currently has a shed roof but it only drops one course of blocks (8 in) over the 12 feet from front to back. The 2x4 rafters have collapsed so I need to tear off the whole roof and start from scratch. I'm thinking of going back with a hip roof. I know I'm going to need to somehow level the tops of the walls. I'd prefer to just remove one course of blocks from the front and the sides (which have been cut at an angle). Problem is the windows on each side have concrete lintels that extends about 2 1/4 in above that level. (see pics) I'm wondering if I can just put a 2X4 pressure treated plate, then install a plywood spacer to the top of the lintel then put another 2x4 over top of all that. Maybe attach to wall with J-bolts going through all of it?
Another option would be to go up to the level of the front, but I would need to lay block around the three sides and cut blocks to appropriate size above windows. Since I've never done any masonry, I'd rather avoid that.
Any opinions or other ideas?
Second part of the project is that I want to enlarge the door so I can drive a riding mower through it - probably about 5 ft wide or so. From what I understand, typically, a lintel would be installed to span the opening and then a 2x frame would be installed inside the opening. I think I could attach the sides with a ramset, but I'm wondering about the top. Seems like a 2X4 would sag over time. If I have a steel lintel, do I somehow attach to it? Maybe double 2X4? or use a 4X4? I also think I could use U shaped block and rebar to make a lintel but I'm not sure if that comes in 4 in? A friend of mine that has construction experience recommended just using a double 2X6 header - Like you would do on a wood frame wall. That probably would be easier, but I'm not sure how I would trim the outside to make the outside look right. Again, any ideas?
I haven't started anything yet, just want to have a plan in mind before I go to get the permit. Thanks for any help or suggestions!
