1 - 7 of 7 Posts
#1 I would never buy one of these.
Reasons being, way to flimsy, near impossable to keep the door working right.
I've only installed one but have torn down dozens.
Unless you build a full platform floor out of 2 X 8 pressure treated and at least pressure treated decking boards or Advantec subflooring you going to have issues.
just a option, I have seen a few Tough sheds and they have a decent idea for foundation.
They use a heavy gauge metal stud for foundation, is basically 4 sides with studs running in between and whole thing is sitting on concrete blocks.
As others have said, not worth the $300 for the product you are buying, then build a foundation, and then pay extra for a floor. Could build something cheaper then what you are paying now.
But using metal studs for bearing walls as a foundation, is a cheap alternative and should work for you.
· "You can do anything"-Mom
What size are the pavers?
How much does the shed weight?
What kind of soil is it going on?
If you've been working with them for 15 years haven't you run across how to build a proper foundation for them?
right now i am debating about doing a full perimeter of 15 3/4 square pavers, and just doing a 9 6x17" pavers. the shed its self wont weight more then 300 lbs between the metal and the deck. the soil is a clay like material.
1 - 7 of 7 Posts
