I have been researching this same topic. It seems that there are two ways of doing it. One being to take a diamond blade on a grinder and cut a narrow slit in the existing brick and install what is called a reglet. This is how they transition from a parapet to the roof in those applications. Anyway, you then bend some flashing on a break so that about one inch actually embeds in that groove that you cut. You then seal the top of that joint with a bead of good roofing cement. I am still trying to figure out a few details like do I need to set this flashing in mortar in that slit and do I counter flash.
The other way they do it is to just laminate the flashing directly to the brick without cutting that channel and ducking the drip edge in there.
