1 - 10 of 10 Posts
Stay-at-home GC
Would depend on where you are located. Snow loads?
A Little Of Everything
oh yes, sorry. Washington, DC. seldom more than 2 ft of snow.
thanks
There are several factors - not the least of which is what you're using for material and supports.
I just built an 8x12 shed this fall. I used 2x6 "rafters" on 16" centers. 5/8" plywood sheeting. It has a slightly less than 3-12 pitch.
Is there some particular reason you're wanting to go with the least pitch possible?
Discussion Starter #5
how does 3/12 translate into degrees ?
why smallest pitch? i don't want the shed to rise any higher than it has to.
thanks
Stay-at-home GC
Also need proposed rafter layout. Trusses or stick, on center spacing?
thanks
I don't know for sure what the degrees would be. A 12-12 pitch (rises 12" in a 12" run) would be a 45 degree angle. So I assume that a 3-12 would be one-forth of that, or about 11 degrees.
There are many things you should consider with the roof of your shed. If you go with a gambrel/barn roof, you'll have more "off the floor" storage. Also, a higher pitch will give you better water/snow run-off.
I think you've got a good start - THINKING through what you want to do, and asking questions. :)
Framing Contractor
3/12 is 14.04 degrees
4/12 is 18.43 degrees
Are the rafters spanning the 11' or 9' side?
Just curious as to why you want it in degrees.
What size rafters and ridge are you going to use? What will the overhang be?
1 - 10 of 10 Posts
