This panel is suitable ONLY for use as service equipment. Hence the permanent bonding of the neutral to the enclosure.
Your idea to use an isolated ground bar kit for the neutral is intriguing, sort of a back-door way to use it as a sub-panel. :huh:
I see no problem with this work-around as the intent of the Code is fulfilled. :whistling2:
