What are you trying to do first? Build another floor inside of it? Lock it together?
Because I'm just not comfortable holding up floor joists with 10d and 16d nails...even if you have a good number of them...at the ribbon-to-stud and the joist-to-stud connections.In my ole balloon framed houses, the ribbon board is spiked into the studs, the floor joists are then run from sheathin' to sheathin', 'n spiked into the studs, 'n the ribbon,....
I have no doubt. There's a cat across the street from me. Looks like he's been on this earth a good 8+ years. I see him regularly cross our busy street, and quite slowly I must add. I cringe every time. But he's been doing it for many years. Does he know what he's doing, or is he just very lucky? Who am I to say? I just know I don't let my cat out front.Btw,.... My houses are well over 100 years old, 'n still standin', quite solidly,....
Ayuh,.... Whatever,.... I thought you came to this forum for Ideas,....I have no doubt. There's a cat across the street from me. Looks like he's been on this earth a good 8+ years. I see him regularly cross our busy street, and quite slowly I must add. I cringe every time. But he's been doing it for many years. Does he know what he's doing, or is he just very lucky? Who am I to say? I just know I don't let my cat out front.
Buddy, I didn't mean to tick you off. I'm not putting your approach down, but I am saying I wouldn't personally trust it. You took the time to give me your ideas, and believe me, I appreciate it. Short-sistering the studs is a structurally solid idea IMO, but I can't bear to kill trees to save myself a few hours of notching, not to mention all that added cost.Ayuh,.... Whatever,.... I thought you came to this forum for Ideas,....
But if ya just came here to validate yer idea....
I guess if ya wait long enough, somebody will give ya the answer you Want,....
Good bye,.....
I doubt that any answer that will be given, would be good enough for the OP.Ayuh,.... Whatever,.... I thought you came to this forum for Ideas,....
Good bye,.....
Man, what a way to start the week.I doubt that any answer that will be given, would be good enough for the OP.
Ayuh,.... A glorified lag bolt,..??..??4. I am asking whether use of Ledger LOKs to fasten the joists to the studs seems like an acceptable alternative to installing a ribbon.
Glorified indeed. No pilot hole, and higher shear strength...and a good bit more moneyAyuh,.... A glorified lag bolt,..??..??
Go for it, but I'd still put a ribbon board under 'em lagged to the studs,...
