is it OK to share a grounding bus hole between two wires coming in? thanks
A amakarevic · Registered Joined Apr 12, 2007 · 2,331 Posts Discussion Starter · #1 · Jul 13, 2011 Only show this user is it OK to share a grounding bus hole between two wires coming in? thanks
O oleguy74 · Registered Joined Aug 23, 2010 · 480 Posts #2 · Jul 13, 2011 Only show this user as long as they are both grounds and same gauge.also some panels allow and some don't.read the lable.
A amakarevic · Registered Joined Apr 12, 2007 · 2,331 Posts Discussion Starter · #3 · Jul 13, 2011 Only show this user why do they have to be the same gauge ?
O oleguy74 · Registered Joined Aug 23, 2010 · 480 Posts #4 · Jul 13, 2011 Only show this user amakarevic said: why do they have to be the same gauge ? Click to expand... if they are diff gauge,the smaller may not get tight.
A amakarevic · Registered Joined Apr 12, 2007 · 2,331 Posts Discussion Starter · #5 · Jul 13, 2011 Only show this user oh, OK. makes perfect sense.
O oleguy74 · Registered Joined Aug 23, 2010 · 480 Posts #6 · Jul 13, 2011 Only show this user also only one neutral under a screw on neutral buss.
