Happy New Year to all. I'm new here and looking for some great advice :smile:
I 'm updating 2 side-by-side 5'x9' bathrooms and they don't have fans. The tub and shower are either side of the shared 5' wide wall. I don't like ducting fans through the roof - Canada winters can be so cold - so I put in a dropped ceiling each side and made this wall deeper to allow ducting to go down to a laundry room below which also has a dropped ceiling.
Originally I wanted an inline fan there, removing air from both rooms but with dampers & control over which room is being cleared.
I'm taking a second look at this plan (mainly because of cost) and wonder if 2 Panasonic fans will be a better option. It's the "how to exit the air" part that I need help with please.
These fans are 4" duct, 80-100 CFM with LED lights. I'd connect individual 4" ducting in the ceiling and down the wall for each fan - then use a Y and 6" run to exit the house. Each run involves 2 x 90 elbows. Will this arrangement minimize air being pushed into the fan that's not running? They have back-draft dampers. There's also that mysterious factor called static pressure that's lurking around eh?....:vs_whistle:Looking forward to expert comments.
