I helped my two neighbors install a shallow point well, working well no problem. When I did mine I find that the water pressure is very low, or the pump seems to be struggling to pull water from the point. It is 1/2hp flow jet with 1 1/4" galvanized pipe aprroxiamtely 18 feet in the ground. all pipes and fitting are securely fastened, the only difference is I am using an extension cord and theirs are hard wired. Is there any special i should be looking for? check valve seems to work well, just cant get enough water pressure, very discouraging since the others work well. Can it be related to slope of land? I dont kknow just throwing it out there, hopefully someone can come up with something i havent though of.
thanks everyone. for all the help in the past...
