You have to go thru the roof
Thank you for the video. I still don’t understand why you must go through the roof. How it seems, as long as the stack vents higher then the water, the system will work properly. Am I missing something?
It is also about the gases leaving the sewer system. I don't know the rule but I am sure there is one. The reason for traps is about sewer gas.You have to go thru the roof
You can tie individual vents together as long as they intersect 6" above the flood rim of the fixtures served. Doesn't matter if it is in the wall or attic. As you connect to other vents, you need to maintain the proper sizing and lengths too.We are almost to the mechanical stage of our remodel and the one thing that still has me confused (and always did) was plumbing vents. I understand the basic idea behind them but actually installing them is a different story.
My MAIN question regards tying them together somewhere and just venting out a single pipe. The 2nd floor will have 2 full bathrooms on it. Is it “wrong” to run a separate vent for tub, toilet and sink into the attic and tie them together up there? I haven’t really paid attention in attics too much but I don’t recall ever seeing a bunch of pvc piping up there except for the vent going through roof.
And my last question is, aside from possible problems with animal blockages, is it ok to vent out a gable wall instead of through roof?
