First things first----have to tested the pump to see if it works? Do this by unplugging the two cords ---separate them and then plug in the separate plug---
Only the bottom fitting(check valve) has threads---all other are glued (solvent weld) and need to be cut---and reattached using a glued in coupling or a rubber Fernco fitting.
Test the pump and get back to us.
