1 - 11 of 11 Posts
· Super Moderator
Take a pictur of the location of the panel, and we can give better directions.
You will have to add a subpanel from the main panel by removing 2 circuits and installing a breaker, feed the new sub panel, the connect the 2 removed ciruits to the new panel.
250 amp breaker
yep, and if you happen to have a panel that makes them(like square d), you could get a 15/15/250 breaker or a 20/20/250 and put your gfi outside since you'll need a disconnect anyway.
Question to wirenut, are you being scarcastic???????????????????????
· Electrical Contractor
I'm not sure what you mean? I was saying that Square D makes "quads" that would be 2 single pole 15, or 20's and a double pole 50. Just so happens the OP has a homeline panel.
http://ecatalog.squared.com/fulldetail.cfm?partnumber=HOMT1515250
PS. It looks like you may have a straight 30 rather than a 30/40 panel. I dunno. If it's a straight 30, no tandems or quads in there.
Remove four 15 amp circuit breakers.
Install two 15 amp tandem breakers (like the one on the left side, a couple/few up from the bottom) and hook the four 15 amp circuits there.
This will leave you with two full spaces for your 2 pole 50 amp spa breaker.
Discussion Starter · #10 ·
Thanks
Thanks guys. 220/221 you got it. I wasn't thinking and should have gone there, because that looks like what the pool guy did. I am calling a pro to do the work and will make sure of the total load margins, but I really wanted wanted to make sure of what I was looking at before I dove in. Thanks again.
· Resident Electrician
You can use what they call tandems or piggyback breakers on some of the 15amp and 20amp circuits. I would do it with circuits that do not have a lot of load on them. Like dining room plugs, living room plugs, or a light lighting circuit.
My bad 220/221, I didn't read your post before I posted. You are exactly correct though.
1 - 11 of 11 Posts
