I am changing our panel to 200 amp service and in the process updating all of the service entrance*to match load and code.* In my area, the owner occupant is allow to pull permit and complete this work.* So far it has brought a lot of joy to me to learn the process and code.
Questions:
1. I plan to run SEU wire from the weatherhead to the meter box and also SEU wire from meter box to the indoor panel.* Is there any reason I should choose SER over SEU wire? I am planning to use 4/0-4/0-4/0 Aluminum SEU.
2. Due to the narrow pathway on the side of my house where the service enters, my local power company wants me to mount the new meter box centered at 6'6" (the current height of old meter box).* We will not have an electrical disconnect*outside.Can I use a PVC as a physical protection sleeve into the building, but no PVC once the SEU wire enters the house until the panel (about 1' of inside wire length before panel)?**
Attached photos show old (current) setup.
Questions:
