Hi everyone,
My ex landlady called me today as she was having electrical issues and asked me to come by and see what I could find. She had low dimming lights, burning light bulbs and other issues. She is 88 years old.
Anyway I looked at what she had and here is what I discovered. This house was built in 1962. There is a breaker panel outside next to the meter base that had 2/0 or 1/0 aluminum wire to the lugs. From there someone put a #6 wire under a 70 amp circuit breaker to the inside house into her closet for all power to this house. This is a 2000 sq/ft house with all the modern conveniences we all enjoy. So this house has been operating on a 70 amp feed for a long time. How I don't know. Should be at least a 200 service. There is a bad connection between the ground on the pipe connecting the panel to the meter base. No other ground attached. There are no grounds between this panel and the house panel.
On the inside what a mess. There are only a couple of grounds but no ground that goes anywhere. There are a few Tandem breakers with what I assume are shared neutrals with 20 amp breakers but 14 ga wire. Neither box appears to be grounded or bonded correctly. This whole house has way too many receptacles and lights for this service. None of the breakers will trip or any of the GFCI outlets will trip. Most of the receptacles show reversed hot and neutrals or open ground. This is throughout most of the house.
Anyway I wanted to get some opinions on how I can help her as she is pretty old and does not have much money and I would hate to see something bad happen to her. If you guys can offer me your opinion I would appreciate it. I know the obvious answer is to call her an electrician bit the prices she was quote for the work is money she does not have. I have attached the pictures here for your review. Any help is appreciated.
