my 1990 house was built with 2 water heaters which each feed a zone. Since we have recirculating loops on each zone, I refer to them as "loops," of which we have 2. In other words, they are plumbed in parallel. When we bought the house, one hot water heater had kicked the bucket, and that heater was removed from the system. The 2.5 yrs we've lived in the house, we've never run out of hot water off the single 50 gal heater, but it was re-plumbed to run at max and then a mixing valve cooled it off a bit before it tee'd off into each zone.
When my wife called my yesterday to let me know the last water heater - from 1993! - had given up the ghost, I decided to replace both. I got them both plumbed up and going how they were originally installed, in parallel. I know in other homes that we've owned which were newer, they installed the heaters in series, one fed into the other. Obviously, the benefit of in series is the combined capacity is available to any where in home, versus it being dependent on where you are using water. But, there is a low probability we would run a single heater (50 gal) out of water is there any other reason to hook this up in series? OR should I just let it ride as is? Thanks!
