Hi All - thanks for taking a look at this. I understand that a professional will handle this, but I wanted to know if anyone here has ever experienced this situation?
Septic tank found under driveway -:vs_mad: what are my options?
We are looking at a home, built in 1980 which has been renovated over time. It sits on 5 acres. Permits show that a driveway was poured in 1990. When attempting to find the septic tank so it can be inspected, 2 septic companies and a GC could not find it. They use standard probing. The Realtor hired a plumber who first wanted to try a snake method vs using the line locator. He used a Sectional machine and put the cable down the vent pipe on the roof. Turned it on and we went hunting. Turns out we heard the rattling under a particular part of the driveway slab, perhaps poured at a different time, as the expansion joints looked different than the original.
My assumption is that they will rip up the concrete, locate the septic, pump it, fill it with sand, get access to the drain line and hook up a new septic in another part of the yard and bring everything up to code. They are not sure where the leech / drain field is.
I am curious if "they" think they can save money and reuse this somehow and put a manhole cover over it. I don't think that is acceptable. I assume you should not be driving over a septic tank to begin with, and that a driveway over a system is not up to code.
Any stories to share?
Thanks all - have a great night
