You are basically dealing with a system that has most likely never properly maintained.
If the tank was never drained and the leach field never inspected, you need to get it done.
If you have had alot of rain in a short period, yes the ground could be so saturated, that it will not take anymore.
Since the tank was just emptied. It is going to take a while to find out if the full tank was really the problem. You need to get the tank emptied per the schedule that the company that emptied it, gave you. Should be on the bill, along with aprox. gallons pumped out.
How long ago did you buy the place? Eas an inspection ever done on the tank and leach field? Also you should have been given record of when it was originally installed. If not. Your county should have it on file.
